RX2 with MMC5 "oversteering"
This post has 4 Replies | 0 Followers
jesperb
Posts 80
Silver Member
jesperb Posted: Sun, Jun 15 2014 8:35 PM
My RX2 - not often used i admit - has started "oversteering", best word i can come up with.
Mechanically it's in great condition, sound is almost OK, but it oversteers when i turn up the volume.
The RIAA is an external noname and cheap, but has been functioning OK up until now.
Grounding between RIAA and the RX2 is likewise OK.
Tracking is adjusted to 1,5g as per the instructions in the manual (as it was before the problem occurred).
Any ideas ?
Cheers,
Beogram TX, Beovox S45, Beovox MC 120.2, BeoSound 1, CX50, Beovox S75, Beomaster 2400, Beomaster 5000, Beogram 5005
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Jun 15 2014 10:13 PM
Suspension failure on the MMC5?  Commonplace with old MMC cartridges but it can be rebuilt to as new (or in the case of an MMC5, made better by building to a higher spec such as an MMC2).
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jun 16 2014 7:06 AM
Battery driven RIAA ?
jesperb
Posts 80
Silver Member
jesperb replied on Mon, Jun 16 2014 7:39 AM
Thanks Dave & Martin,
The RIAA is power driven but the "cheapest eBay" so i'll try to swap it as soon as i can get a hand on an upgrade - which was needed anyways.
I'll get back with a result, when i have swapped the RIAA, then we can discuss option(s) for rebuilding the MMC5.
Jesper
jesperb
Posts 80
Silver Member
jesperb replied on Fri, Jan 8 2016 9:29 PM
Better late than....
Just wanted to let you know a new RIAA (from Sounds Heavenly) did the job.
RX-2 then played fine for a couple of weeks, now another problem. I guess i'll have to open a new thread Stick out tongue
Cheers,
Page 1 of 1 (5 items) | RSS
