What can be wrong?
beopiranha
Germany
Posts 125
beopiranha Posted: Fri, Jul 6 2012 6:37 AM
Hi all,
I have a question. Beosound 5 Encore and Beosound 9000 are using the same lautspeakers (BL4000's +  BL11) I have very satisfiying sound when I use A.Aux of BS9000 (Ipad via Airport Express). Bass is perfect, crisp treble and vocal is also very clear.
I could get same terble and vocal performance from BS5E but bass is much lower than BS9000 A.aux out. I'm using equalizer of Itunes (adjusted : Rock) and that's the only difference that I can tell.
So, the question is what can be the reason of this bass difference?
1 - Equalizer of Itunes? (I turned it off but there is still difference)
2-  Cabling (I use wrong cable or Y)
3-  Difference of BS9000 to BS5E and this is normal !!
What do you think?
Beovision Avant 55 / BV 11-40 / BV7-40 / Beovision Avant / Beosound 9000 / Beosound 5 Encore / Beosystem 4500 / Beosystem 6500 / Beocenter 9000 / Beolab 5000 / Beolab 18 / Beolab 19 / Beolab 11 / Beolab 17 / 3 sets of Beolab 4000 / Beovox Red Line 60.2
Page 1 of 1 (1 items) | RSS
