Hi Guys
I hope that you can help me.
In my setup I have a Beosound 3000 that until now has been working flawles. But all of a sudden the radio has decided not to work anymore ?
I have had it opened and there is no visible damage to any of the components.
Looking in the service manual, I found to place the unit in test mode:
"Sound 0258"
and look in the error counter (TM27) and it says:
IO error 6, "FEP Communication Error".
Made a reset and put the unit back on the wall and all of a sudden the radio worked again. Happy
But now, after a good night of sleep, turning the radio on and nothing !
Checking the error counter and the same is stored again.
Anybody has any idea ?
Best
Henrik
This moght be a dying processor board. They become rather hot and loose contacts or burnt parts can be caused.
Example: BS9000 upc board ended dead.
