Bemoaster 1200, 3000uf Capacitor Polarity
This post has 5 Replies | 0 Followers
Jamian
OREGON, USA
Posts 33
Jamian Posted: Wed, Jan 27 2016 6:12 AM
Hi
Almost finished the re-cap of my BM1200.  Only thing is I am totally unsure of the correct connection of the 2 3000uf caps.  One had clearly marked polarity, but the other was an old original Wicon.  I can not decipher its polarity marking.  I attached the multimeter to determine polarity but do not trust the outcome.  Rather than run the risk of blowing up my hard work, I am posting to see if some one can tell me which wires (yellow, green; orange, blue) go to positive and negative (obviously the new caps are clearly marked).  Here is the story so far-
Original BM1200 caps.  The right hand cap is clearly marked, so I copied that for the new cap.  The left cap is not clearly marked so I measured the DC across the connectors.  That suggested the right connector is +ve.  This is the initial information I followed when connecting the new caps...
1200 initial connection based on multimeter reading of DC across old Wicon cap (which I do not trust).  yellow-, green+; orange+, blue-.  This did not feel right, so I also measured the DC across the clearly marked old cap.  I got a -ve reading when red was connected to + and black to the black connection; strange. Danger, danger!!!  Time to reference my working BM1001...
My BM1001, which I just opened up for reference.  The polarity of these according to my multimeter (DC reading) is yellow+, green-; orange+, blue-  That would seem to be logical.  Is this correct?
Thanks for the advise!
Love = My  Beomaster 1001 + Beovox 2700
Orava
Finland
Posts 991
Orava replied on Wed, Jan 27 2016 7:34 AM
Hi
I have same operation ahead. Do yuo happend to have list of caps neede?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jan 27 2016 3:54 PM
Usually, the square (and triangular in double caps) marked pins are positives.
Doesn't it say "Plain Neg." on the old cap ?
Jamian
OREGON, USA
Posts 33
Jamian replied on Wed, Jan 27 2016 8:26 PM
The cap does read 'plain negative.' I looked that up on line and found a guy who had the same challenge as me on a different amp.  He concluded the flatter/simpler pin was +ve.  that contradicts my DC reading on my working BM1001.  What does 'plain negative' mean?
There is a slight difference between the pins in the BM1001 (Last image above).  The left looks like a slightly smaller diameter and has an impression in it.  The right is slightly flatter.
Jamian
OREGON, USA
Posts 33
Jamian replied on Wed, Jan 27 2016 8:28 PM
Hi Orava - I simply got my cap kit from Dillen (he has posted below.  You could PM him).  Comes with simple visual instruction.
I also referred to the user manual to help locate pins on the back of the PCBs and will use in a while to adjust the trimmers.
Jamian
OREGON, USA
Posts 33
Jamian replied on Fri, Jan 29 2016 5:44 AM
OK, sat down with the service manual this evening -
Using the PCB diagram (and looking at the actual PCB), I can see that the yellow wire goes to TR36 and the orange to TR38:
Then looking at the circuit diagram I could see that T38 goes to the Left Speaker cap +ve and T36 goes to the Right Speaker cap +ve.  So, orange and yellow will connect to the cap +ve pins.  Using the PCB diagram (above) and following from the speaker connections back to the caps confirms the blue and green wire connections:
So I will be switching my yellow and green wires around; which matches my readings off my working BM1001.
Eureka?
Page 1 of 1 (6 items) | RSS
