Beotalk 1200 power supply
Sbfbdo
Posts 7
Sbfbdo Posted: Wed, Oct 24 2012 8:02 PM
I need some help, I have a beocom 1200 which I purchased, it didn't come with the power adapter/ splitter. It only had the phone lead coming out the back. I am in the uk and would like to get this working.
Does anyone know where I can get hold of an adapter or something that would work.? I can't make a cable myself but am willing to buy one. Any thoughts?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Oct 25 2012 9:35 AM
Take a look at the old/archived forum. I'm fairly certain that Keith posted some wiring diagrams of the connections in the splitter.
Maybe Steve at Sounds Heavenly can help?
Graham
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Oct 25 2012 10:16 PM
There are two versions of the splitter. One has a white dot the other one doesn't. This indicates which version of the splitter works with PSTN bases, BeoCom & BeoTalk products. If you get the wrong splitter it won't work.
I am back in work on Saturday and will check the part numbers and check availability if you haven't had an answer by then.
Opman
Sbfbdo
Posts 7
Sbfbdo replied on Fri, Oct 26 2012 10:38 AM
Thankyou Opman that would be very helpful.
Simon
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Oct 27 2012 11:01 AM
Hi
I have checked for the part numbers that you requested. Unfortunately the power supply (8040045) and gry cable from the BeoTalk1200 to the splitter (6100351) are no longer available to order from Bang & Olufsen. You will have to drop lucky and see if your nearest dealer has these items in stock or pick up second hand.
The splitter that you would need is part number 7229176. This is the version with the white dot and is supplied with both BeoTalk1100 & 1200 plus the old original pyramid bases. The other splitter (7229165) has no white dot and is used for the PSTN base and BeoCom4.
Good luck in your quest.
Opman
AndrewEcosse
Posts 77
I now need one of these power supplies too. Is there no non B&O off the shelf option?
Page 1 of 1 (6 items) | RSS
