In the products section I can see that the SP 6-7 fits the Beogram 1000 and similar decks.
Which Beograms are the similar decks?
/riis
Does it fit all decks with the round tone arm?
riis: Does it fit all decks with the round tone arm? /riis
Yes it fits BGs with this type of tonearm, BG 1000, 1001, 12XX, 1500, it was later replaced with the SP 14
Søren Mexico: riis: Does it fit all decks with the round tone arm? /riis Yes it fits BGs with this type of tonearm, BG 1000, 1001, 12XX, 1500, it was later replaced with the SP 14
What about BG 2000
I think that the later arms are not happy with these SP6/7, and the SP10/12/14 will not be happy on Beogram 1000 decks either. My little experience.
Jacques
Werent there some angle difference..?
Earlier arms had different angles, as found on the 42V I think. The SP1/2 don't fit the Beogram 1000 at all.
Arms equipped with a spring for tracking force don't work well with SP10/12/14.
