JRemote and Beoply A6
jgreen8240
Posts 47
jgreen8240 Posted: Mon, Feb 15 2016 1:44 AM
Wondering if anyone has experience with Jremote - I am using the JRiver generic DLNA. JRemote recognizes the A6. Problem is when I choose a playlist the first song plays and then the A6 goes to the last song played prior to the playlist. This may of course be user error so any suggestions?
Thanks folks!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Feb 15 2016 11:42 AM
jgreen8240:
Thanks folks!
I use JRiver aside to Twonky as DLNA server also. I have used JRemote incidently to play stuff on NL products (BV11, Essence). Never experienced problems though. Until now I didn't use JRemote as DMC for the BP A6 (DMR).
What is the settings in JRemote? Just one track or play from the selected track or.....................
jgreen8240
Posts 47
jgreen8240 replied on Mon, Feb 15 2016 12:32 PM
Thanks for your help again. I am a novice so not sure all your acronyms/products so apologize in advance if I miss something. To answer your question through a little trial and error I think I might have some answers. Seems the BEoMusic app ( underwhelmed with it so that's why I am trying to find a controller that works better) treats the playlist as one song (I do select play all) and when the first song ends the beo goes to the next song in its queue and that will be whatever I last listened to. The problem is the beo app will not always let me clear queue. However when I was able to (and I don't know why it allowed it one time and not others) the playlist played as expected. Simple question may now be  is do you have any experience with the intermittent clear queue issue? Thanks again!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Feb 15 2016 7:18 PM
jgreen8240:
Sorry I shouldn't have use the acronyms. It only add something if you know the meaning.
tap the icon
tap the sentence. the list to play should be deleted. Works all the time on different machines!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Feb 15 2016 7:22 PM
Strange! the help/answer need to be moderated? So wait until the moderater moderated
oehh....... excitement (about nothing)
jgreen8240
Posts 47
jgreen8240 replied on Tue, Feb 16 2016 12:22 AM
Thanks but the problem is sometimes songs show up in the queue and sometimes nothing does even though they are there. It's the intermittent issue that creates the problem. Open to any ideas.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 16 2016 7:00 AM
jgreen8240:
Open to any ideas
(Wifi) Network issue?
In my setup this always works to delete the actual list
Page 1 of 1 (7 items) | RSS
