Reposting this in the workbench forum as not getting any replies.
Recently bought a mint beolink 7000 remote, i'm using with an AV9000 coupled with a beosystem 4500 via the 1610 audio kit.
Ive fitted an original new old stock AV9000 STB-C control module in the back of the AV9000 which is now controlling my Humax digital box to give digital TV on my AV9000, and i can use my Beo4 remote, and also a Beolink 5000 as it has the early 1.2 two way software.
I'm only able to sellect the digital TV on source V.AUX off my beo4 remote, or by pressing SHIFT TV on the beolink 5000 remote.
However, i really want to turn on the TV and use with the beolink 7000, i'm happy with just basic functions, but sadly my Beolink 7000 seems not to have V.AUX on its menu of extra sources, mine i think is a later one having CDV on the list instead, but not really sure to e honest.
Can anyone confirm if i'm able to select V.AUX on my beolink 7000? and if not am i able to program in another source such as V.TAPE2 to work the Humax digital TV box?
And if so, what do i have to do to program this in?
Hitting a brick wall with this as no one seems to know anything about what i'm trying to do here.
regards<Phil
I have 3 BL7000 here... V2.1 V3.0 V3.1.
None of them has V.Aux available. Tested right now.
I think, just Version 1.3 has Vaux... but then no CDV. Not confirmed... i have it not here.
Die_Bogener: I have 3 BL7000 here... V2.1 V3.0 V3.1. None of them has V.Aux available. Tested right now. I think, just Version 1.3 has Vaux... but then no CDV. Not confirmed... i have it not here.
I have an V1.3 right here, it has V.AUX but no CDV, so you are correct..
/Weebyx
