Today the BV7 when put to standby does not have a steady red light but a pulsating red light - any ideas what might have caused this?
The DVD works ok and the BT box as does the Ouverture.
TEL
Flashing stdby light usually indicates a ML error.
Maybe it helps to disconnect the BV from the mains for some minutes and reconnect.
Stefan
Hello Stefan
Many thanks your prompt reply and apologies for my delay.
I've done as you suggested, left it for 20mins and all seems to work as it did - with the standby light a steady red.
