Beolab 7.1
This post has 1 Reply | 0 Followers
pauljrog
Posts 92
pauljrog Posted: Wed, Feb 17 2016 9:46 PM
I want to use a Beolab 7.1 as part of my music setup.
I have a Beocenter 9300 connected to a Beolab 2 subwoofer then to 2 Beolab 4000 speakers
I use mk3 powerlink cables and I want to connect the Beolab 7.1 to one of the Beolab 4000 speakers.
Will this work ok? I've heard you might need a trigger unit??
Paul.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Feb 18 2016 5:58 AM
The 7.1 will work 100% as a pair of BL4000, so if you daisy-chain it to one of the BL4000 that turns on correct, then the BL7.1 will turn on fine.
I have used a BL7.1 as tv speaker for many years with various masters (2300/Ouverture/3000/4500/7000) and they all turn on the 7.1 without issues.
/Weebyx
Page 1 of 1 (2 items) | RSS
