I have an ATV 3rd generation, which fits beautifully in a compartment at the rear of the TV. Will an ATV 4K fit in the same compartment?
Quite sure they are the same size. Check on Apple webpage.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Double post. Sorry...
Yes, Same size. Easy googeling
Just to be clear, there are five generations:
2nd and 3rd are the same size.
4th and 5th(4K) are the same size.
Both the 4th and 5th generation have the touchpad remote.
I have the 4th generation and it does not fit in my Beoplay V1-40. Had no problem with the 3rd gen.
I have no clue if the compartment in the Beovision 11-55 is larger than the one in Beoplay V1.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
Hi
Thanks for all replies. There is a difference in the depth. Third generation is 23mm and 4K is 35Mm
Just wondering if there is anyone out there with an 11 who has bought an ATV 4K, and found it fits
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's...
Replaced my old 3rd gen ATV with the new one in a BeoVision 10-32, a tight fit - but I got the cover to lock back in place and the new 4k ATV is out of sight.
Why did I put a 4k ATV in a 10-32? My local cable provider went from a small STB to providing an app for TV content - app only available on the new ATV.
Roger
Hi Gennaro and Roger
so one of you says it fits and the other that it doesn’t! Where do I go from here?
Two different tv’s, though!
