It all began with the love of a remote control
This post has 7 Replies | 2 Followers
Tony
London
Posts 2
Tony Posted: Sun, Jul 24 2016 9:40 PM
As poorly student I walk past a shop selling B&O products and fell in love with the looks oh the b&o 6000 system particularly the remote I decide that one day if all went well I would buy one ....
Many years later I have now acquired a 7000 system in black and a pair of beolab 5 several pairs of beolab 8000 beolab 1's a 7.2 centre and a pair of beolab 9's
I am now looking for some advice on how best to put together a AV/music system . I had previously run an AV system with a yahama  dsp-a1  which has sadly died so I am no looking to restructure my system an am looking for advise on the best way to achieve this .
It would appear that B&O do not produce the equilivant  of an AV Reciever . So it would appear the only choice is to use an AV Reciever with pre outs that can be used to drive the B&O active speakers .
in addition I have recently acquired a transmitter 1 and half a dozen Reciever 1's so I was thinking of connecting the speakers up wirelessly . Is it a good idea to connect up the lab 5's this way or will I lose out on sound quality ?
Can anyone recommend a suitable AV Reciever for the job ?
beojeff
USA
Posts 2,012
beojeff replied on Sun, Jul 24 2016 11:21 PM
The only way to keep that B&O integration and magic is with one of the B&O AV receivers: the BeoSystem 3 or the BeoSystem 4. Depending on your needs, the BeoSystem 3 might be sufficient and can be found quite reasonably priced on the second-hand market.
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 24 2016 11:37 PM
Or cross our fingers and see if we get version 5 announced at the AV show in Berlin at the end of August !
BeoNut since '75
beojeff
USA
Posts 2,012
beojeff replied on Mon, Jul 25 2016 1:16 AM
elephant:
Yes! My dream BS5 would support UHD and Dolby Atmos. Otherwise, It's worthless.
Tony
London
Posts 2
Tony replied on Mon, Jul 25 2016 11:05 AM
Thanks guys for the quick replies I have sourced a Beosystem 4 bought and paid for delivered in a few days .
Now can anyone enlighten me on the issues with possibly connecting the beosystem 4 to a transmitter 1 and then the speakers to individual receiver 1's  will I lose out on sound quality particularly with the beolab 5's ,  presumably encoding end decoding the signals is not without loss ?
Iets hope the beosystem 4 is given some upgrade options .  I guess a beosystem 5 is inevitable as the four does not have enough channels to support the newer formats .
zerocool143
Posts 94
Hi Tony,
Are you aware that the beolab 5's can't make wireless connection with the transmitter 1?
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Mon, Jul 25 2016 4:27 PM
The Beolab 5
If you are serious about using the Beolob 5 to the max, i. e using the digital input, you should know that after Beosystem 3 (BV-7) the CD command used for enabling the digital input no longer gets parsed correctly if at all!
The Beosystem 4 does NOT support the Beolab 5 in the digital mode, HOWEVER, the AVANT might!
I say "might" because so far nobody has confirmed the inner works of  the BS 4 engine!
The idea would be, as you alluded to earlier, to simply use the WISA interface and a Beolab Receiver 1, and the run the speakers in "non-B&O mode"
Remember, - the maximum sample rate at the digital input is 88.2khz!
Barry Santini
New York
Posts 543
First off, I would not get too hung up on sending the BL 5s a digital signal. Today, more advanced DACs, like the Meridian Explorer 2, offer superior signal processing, including the ability to offer MQA decoding. I use my Explorer 2 outputting from Mac mini-stored FLAC files and inputting to my A.Aux in on my BS9000 to my BV9 and onto my 5s in a surround set up.
Terrific. The Explorer 2 is only $299!
Page 1 of 1 (8 items) | RSS
