BL2000
carlgg
Posts 4
carlgg Posted: Sat, Mar 5 2016 2:47 PM
Hi everybody,
In my masterlink system there are two link speaker BL2000, which are working very well regarding Radio, CD, N.Music and N.Radio.
Recently I have upgraded the BS9000 with a ChromecastAudio connected to AUX-input, where  command A.AUX is used for operation. It works fine on all units (BS9000, BS3000, BV6-26, BL3500), but without the BL2000's. They don't react at all on the command A.AUX. It seems they don't recognize that type of command - they are still in off position.
Do anyone out there know if this is a SW issue, or it doesn't matter which version of software is used. Simply, the BL2000 is not compatible with A.AUX.....?
Thanks in advance!
Best regards
Carl G Gustafsson
parasound
Sweden
Posts 69
parasound replied on Sat, Mar 5 2016 11:57 PM
Hi Carl!
They don't under stand that command, be course they missing the newer software update. (you need v1.6?)
I have the same problem. I have solved this with this solution: Start your system with A.aux in another room first, then push the power button on your Beolab 2000 unit, works great for me, but its not perfect.
Then you can turn of the system in the first room, and still enjoy your Beolab 2000.
Hope it works for You
//Marcus
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Page 1 of 1 (2 items) | RSS
