Does anyone know if the handset top and bottom comes apart (hidden clips like the Beocom 6000) or is it glued together? I would like to clean my white handset to remove the yellowing. I have soaked the base white part in Hydrogen peroxide out in sunlight and it is bright white again. I don't think the microphone or speaker would survive soaking for the two days required to whiten the handset case.
