Beolab 5/9 bass
Razlaw
Posts 4,345
Razlaw Posted: Sat, Jul 14 2012 4:51 PM
I was looking at an old B and O catalog. It listed the lowest frequency for the 5 and 9 as 20hz and 30hz.
Looking on the web page they are now listed as 14hz and 28hz. Is this merely a change in measurements or has there been some actual change to the speakers?
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Jul 14 2012 8:06 PM
Razlaw:
The lowest frequency quoted depends upon the reference signal amplitude and frequency and the amplitude you decide to use as the cutoff "limit". When quoting frequency responses and bandwidths it is usual to use -3dB as the cutoff limit as this is the half power point, however there is no recognised standard and manufacturers can massage numbers to quote apparently better performance. B&O in recent times have taken to quoting a cutoff limit of -10dB which will result in a lower quoted frequency for the same speaker (a -10dB reduction is approximately a halving of the volume output). Depending upon the roll off rate this will reduce the quoted bass frequency by an additional octave or more.
Ban boring signatures!
Page 1 of 1 (2 items) | RSS
