Lutron Rania convert standard to pick up B&O signal
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Aug 12 2012 7:02 PM
Is it possible to convert a standard Lutron Rania dimmer to a B&O Rania?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
L1NO
Posts 250
L1NO replied on Sun, Aug 19 2012 9:37 PM
Sadly no. Bosscom (google them)  is able to modify your Beo4 to send the right IR codes. It's a pcb doughterboard that you could install yourself and is almost finished in development.
Chris Harrison
Peak District
Posts 381
I have just purchased a Beotime and wanting it to control some Lutron lights/ or other dimmers without paying a fortune. I'm guessing this cannot be converted.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Aug 24 2012 8:16 PM
I've been researching this and having looked at lots of alternatives have decided to buy a couple of these: http://www.lintronic.dk/ALUDIM.asp
although here in Denmark I have to buy them from B&O dealers (same price)
Page 1 of 1 (4 items) | RSS
