I've recently purchased a Beosystem 7000 which came with a Beolink 1000 remote control.
Im struggling to get the remote to operate the tuner (in terms of searching for stations or changing band).
Can anyone advise whether this can be done via the unit itself or whether there is another remote better suited to allow this to happen?
Try:
Radio-Goto-up/down-store-number-store-store
..to search and store radio stations via BL1000.
And try search function:
"Beomaster 7000 tune"
hope this helps
Stefan
Excellent, thank you for your help...this works a treat.
