beocord 5000 , sound problem : Big scratchy sound, whenever played..
udm77
Posts 1
udm77 Posted: Fri, Sep 16 2016 4:28 PM
Hello guys,
I'm new to beoworld and I need some help and suggestions!
I just got a Beocord 5000 type 4715... whenever I press the play button (with or without cassette tape) , it makes a big scratchy sound. I cant even hear the music itself... I'm a big newbie in this...so I don't know what to do. Do you think its not compatible with my amp? I use a pioneer sx 650 receiver.
Thanks so much for your help!
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Sep 16 2016 6:51 PM
Welcome to Beoworld!
The 4715 is a complex machine, which works beautifully when it does, but when it doesn't...
Anyway, our friend Rudy of Beolover fame has a section on how to work on this deck - of which I have two - which is really comprehensive. He has become a dedicated B&O specialist now and his blog is absolutely superb.
You will have to buy fresh belts from Martin (aka Dillen here) who has them re-manufactured.
Then a full cleanup and re-cap (that means replacing all electrolytic capacitors) and then re-alignment will be necessary once the mechanics are sorted.
Not for the faint-hearted.
You will also find a thread on the archived Beoworld site.
I for one absolutely love the mechanics, with no silly rubber wheels/idlers and gigantic flywheels. But then again, it is a bit difficult to make work properly.
Jacques
Page 1 of 1 (2 items) | RSS
