Hi, my first post here and was wondering if somebody could direct me.
I have a faulty a2 with burnt out capacitors and a transistor that has also chared. I see the circuit diagrams and schematica are available for silver and gold members. Sadly I can't see exactly what is and what is not available.could somebody please advise. If they are available for paid members, how detailed is the info provided?
Thank in advance yo anybody that can help..
Others may tell, but I would not bet that there are anything available for newer products like A2. I doubt that they are ever being repaired.
Is it really worth the hazzle of repairing?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks for your reply.
It is for that reason i haven't yet paid for subscription.
You are probably right hence the absolute lack of information online other than re the batteries.
Commercially no. But the purpose is as much educational as personal use as funds dont permit for a replacement. If it were to be just the replacement of 2 caps and 1 transistor or even if it were more than that then i would believe it was.
Anyone?
Hi
I think there is no shamatics for that item.
Only comlete PCB change.
No one repair it on component level.
but you can tray..
