Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
Hi Newbie,
Beosystem 3 is superb in terms of connections, you can link just about any device to it, including the PlayMaker. All you need is this cable to connect from either PL socket of the PlayMaker to the L-IN and R-IN sockets on either input AV4, AV5 or AV6 of the Beosystem:-
http://soundsheavenly.com/bang-olufsen/65-rj45-powerlink-compatible-to-twin-phono-cable-output-from-new-bo-devices-to-amps-receivers-etc.html
The Beosystem does need to be on, the best option is to leave this always on so that you can play any source at any time without needing to turn on all the plugs.
Page 18 of the Beosystem 3 Reference Manual "Register additional video equipment" covers all the steps to set up the Beosystem. As you are a Gold member of the Forum, you can download this manual here:-
https://www.beoworld.org/manuals.asp
Kind regards, Steve.
Steve.
www.soundsheavenly.com
