Beoremote One & LC2 bug?
This post has 0 Replies | 0 Followers
PhilLondon
London
Posts 3,637
PhilLondon Posted: Fri, Apr 15 2016 10:38 PM
Hi all,
I have a BeoRemote One since a while, and there's a bug in the firmware, which means I cannot control individuals LC2s...
For example I go List -> Light -> Lamp -> 2 and instead of selecting Lamp 2 for future commands it calls the light scene 2 as if I had done Light->  2.
I have verified that the code was indeed sent incorrectly as I could trace it with my BLGW.
I was wondering if any of you with a BeoRemote and an LC2 could do the test... I'd like to find out if a recent firmware would have solved the issue.
Beoworld app with direct photo upload and emoticons.
Page 1 of 1 (1 items) | RSS
