SkyQ PUC
This post has 12 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Tue, Apr 5 2016 6:30 PM
Hello Beoteam
The SKYQ PUC is now out for download. I have also been informed for my BB7-55 it is now available to flash to the TV also.
My install is next Wednesday
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Also I noticed the sky HD PUC has been updated but I don't know what it contains that's new
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
PUC works on the V1
BV7 to be updated at the weekend
Guide button on Beoremore One takes you too planner rather than TV guide which is annoying.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Thu, Apr 14 2016 12:15 AM
Seanie_230:
Hi Seanie,
I don't have a sky q box, so just guessing, but does "MENU -> 1" (equivalent to 'home' button on original remote) take you to the TV guide? if so then perhaps have a chat with the service tech in advance of him coming to update you BV7 as he may be able to swap these two mappings around in the puc tool in order to create a custom puc for both televisions if you'd prefer GUIDE = home, and Menu -> 1 = planner.
Kind Regards,
Martin.
Seanie_230
UK
Posts 2,278
Hello there
Been having a play and it appears you cannot go to TV guide diectly only via the home button.
I have a look online and with the remote and it does not appear to be a way to go directly to the TV Guide like the old remote.
The below shows you the normal buttons for the Bluetooth remote which works the same way but does not use IR or touchpad
https://www.sky.com/help/articles/buttons-on-your-sky-q-remotes-explained
this confirms I think you can only go home or to recordings directly.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Apr 16 2016 12:17 AM
Hi Seanie,
The client whos home I was working in today has just had sky q installed so I took the opportunity to look at this.
It does seem that (with the original remote) there is no way to directly access the TV guide, and instead you have to press home, and then scroll up through the list - seems a little odd but at least this confirms it's not just a feature that is missing from the PUC.
Kind regards,
Martin.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sat, Apr 16 2016 11:00 AM
Hello all
Need some quick help if you don't mind.
My dealer cannot find the SKYQ PUC on the service tool
Beocare said its available now and it works on my V1
Does anyone know where it is or what it's called on the service tool?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Apr 16 2016 1:01 PM
Hi Seanie,
It's available within the PUC Tool so can be saved from there in the current (.decx) format for newer televisions, and/or converted to the old PUC 2.0 (.dec) format for flashing to your BV7 for example.
Ask them to search for "Sky Q" within PUCtool3 (the filename is Sky_Q_V03,01a.decx)
Hope this helps,
Martin.
Seanie_230
UK
Posts 2,278
Hello there
You are a star thank you.
This should put us on the right track
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hello Martin
I have spoken to my dealer who is fighting with the service tool.
He has converted the file to the older TV versions but it shows as a skeleton with no mappings in the service tool
HELPSmile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Apr 16 2016 4:28 PM
Hi Seanie,
I've sent you an email.
Kind Regards,
Martin.
Seanie_230
UK
Posts 2,278
Hello all
Martin is a star and helped to fix it
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Apr 16 2016 5:11 PM
Thanks Seanie,
Glad I could help Smile
Best Regards,
Martin.
Page 1 of 1 (13 items) | RSS
