beolab 5000
This post has 5 Replies | 2 Followers
lotus73jps
Posts 141
lotus73jps Posted: Wed, Apr 27 2016 12:05 PM
hi I have a pair off beolabs 5000 the problem is one of the display panals are not working told it could be a lose conecter but checking the display panal lome to the board all seems ok ? I would like to know if there is somethink else I should look for thank for any help
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi lotus73jps,
This could be as simple as having the wrong version of cable connected.  Beolab 5000 (and other speakers with displays, ie. 3000, 4500 and Penta) all need to use the thicker "fully wired" Powerlink mk.2 cables to get the displays working:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
lotus73jps
Posts 141
hi steve  its not the cables I brought a mk 2 cables from you a couple off weeks ago when I brought the 5000 I was told that the display panal sometimes works ? but have had no joy thanks for your help regards shaun
Posts 2,165
No problem, I always like to check the simplest option first, then we can look at the other possible causes!  Beolab 5000 should have a switch on the side for Audio/Video/Off, have you tried this in both the upper and middle positions please? (one position should give the display, the other position won't) - these switches can easily get knocked, turning off the display.
Steve.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Steve at Sounds Heavenly:
They also sometimes become intermittent I have previously found.
Regards Keith....
lotus73jps
Posts 141
lotus73jps replied on Thu, Apr 28 2016 10:42 AM
hi steve and keith tryed the switches but still no display ? regards shaun
Page 1 of 1 (6 items) | RSS
