I am using the Beosound Moment with my QNAP NAS (Twonky Server), but I have problems in indexing my own music libary. After a few minutes the Beosound Moment is ready (check mark appears).
In the "Settings/Sharing/devices" menu of the twonkey server you can choose different Media Type Receivers for the BS Moment. I habe choose Bang Olufsen EZ2. Maybe this is the problem.
Can anybody tell me, what the right choice is?
Or is the BS Moment after the last update so fast, that indexing the music libary (ca. 13.000 files) is so fast?
Greetings
Mirco
My experience is that is does not matter whatever you choose there. If it does not work for you know, try "generic" and restart the Twonky server.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
MircoHH:I have problems in indexing my own music libary. After a few minutes the Beosound Moment is ready (check mark appears).
QNAP green technology features? The Moment is reading slow your hdd...
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Good Idea. I will check this. Maybe this is the problem.
