Anyone know how to convert 5 pin to a 7 pin din for my Beocord 5500 and my Beogram 3300 phonograph player?
On some of the old B&O 7 pin din cable the outer most two pins can be removed with a slotted screw driver.
They are actually threaded rods that can be unscrewed.
This would be easiest if you have this connector.
Derek
Derek,
Thanks for the reply. I do see threads in the holes. Where can I get these threaded rods?
Thanks,
Matt
