I had a Cona/CX-50 connected to an MCL2A in a link room, which gets its signal from a BC9300. This has worked fine for years, and I recently decided to upgrade to S8s. I added in the Sounds Heavenly attenuator since its getting speaker output from the 9300 amps. It works and sounds great... until I mute or turn it off, then I have a buzzing sound.
Has anyone else experienced this? Or successfully run any power link speaker from an MCL2A?
