I intend to connect a Playmaker to the AUX in on my Beosound Overture
RJ45 -> 7 pin DIN (I suppose that for a short distance a normal cat 7 cable can be used)
Does anybody know where I can find the pin configuration of such a cable?
Peter's 28 Sep post here should help! http://archivedforum2.beoworld.org/forums/t/444.aspx?PageIndex=5
Or buy one 'ready made' from Steve at Sounds Heavenly below! That's what I did!
