BV7-55 Software Update/Beolab 20 question
Razlaw
Posts 4,345
Razlaw Posted: Sat, Jun 4 2016 5:18 PM
I have a BV7-55 that has not been updated for several years. It has Beolab 9s as a possible speaker. It does not however have Beolab 12-3 which are my rear speakers, or Beolab 20 which I have ordered to replace my 9s in front.
Is there a software update for the BV7-55 that would add the 12-3s and 20s to the menu?
And if not, which speaker would be the best selection for the 20s? 9s perhaps?
Thanks!
Razlaw
Posts 4,345
Razlaw replied on Sun, Jun 5 2016 1:53 PM
Got the answer. Dealer provided me with a document on speakers. For older TVs the proper setting for 20s is Beolab with a 3 step volume gain. Also learned from it that my BL 12-3s should be set as Beolab 3s and 1.5 meters added to distance to account for different processing times of older compared to newer speakers when used with a BV7.
Razlaw
Posts 4,345
Razlaw replied on Sun, Jun 5 2016 4:09 PM
edit
Got the answer. Dealer provided me with a document on speakers. For older TVs the proper setting for 20s is Beolab 5 with a 3 step volume gain. Also learned from it that my BL 12-3s should be set as Beolab 3s and 1.5 meters added to distance to account for different processing times of older compared to newer speakers when used with a BV7.
Razlaw
Posts 4,345
edit
Got the answer. Dealer provided me with a document on speakers. For older TVs the proper setting for 20s is Beolab 5 with a 3 step volume gain. Also learned from it that my BL 12-3s should be set as Beolab 3s and 1.5 meters added to distance to account for different processing times of older compared to newer speaker.
elephant
AU
Posts 8,219
Wow !
Are those kind of recommendations published somewhere ?
BeoNut since '75
The Beonic Man
Bristol
Posts 812
Glad you found all the info you needed Raz :)
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Razlaw
Posts 4,345
Razlaw replied on Tue, Jun 7 2016 12:58 AM
BAND'OH!:
I am also. Now just have to wait a few more weeks for the 20s to arrive.
Page 1 of 1 (7 items) | RSS
