Beocenter 9000 => Beocenter 8500
tamtapir
Örebro, Sweden
Posts 521
tamtapir Posted: Mon, Jun 25 2018 5:18 PM
Is the glass sections on the two Beocenters in the topic interchangeably?
/Di ck
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jun 25 2018 5:35 PM
From looking at the repair manual ...
The top 'display' panels share a part number hence should be interchangeable.
The lower 'keyboard' panels have different part numbers, hence may not be interchangeable - but you may be able to swap them with limited functionality.
EDIT:  The BC9000 (and BC9500) has an additional 'Timer' function on the keyboard between 'Mute' and 'Programming' - whereas the BC8500 does not have a 'Timer'.  I would guess therefore that a BC9000 keyboard would work on a BC8500 (obviously without the timer), and that a BC8500 keyboard may well work fully on a BC9000 - you may be able to select 'timer' by simply pressing in the space.
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Wed, Jun 27 2018 8:25 PM
Guy:
Thank you  precise and accurate answer!
Best Regards,
/Di ck
Page 1 of 1 (3 items) | RSS
