Hi all,
During my last hollydays i had the opportunity tu buy a white BM5500 with white BG CD 5500, white MCP5500, and finally a black BL1000. All this for 189€. and it work's. Only the BM5500 has a little problem: i can only install 3 radio stations; (typ 2331 SW: 2.3)
when i ask for another number, it returns to 3. Any idea for this ? Thanks
Zazou
You cannot select a station number where no station (frequency) has been programmed.First tune to the station you want to store - then store it at the number you want.Now you can select it as a source.
