Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
The Encore is a standalone device - so no!
But - as you already have the Playmaker - just* connect that to the Aux-in of the Ouverture.
In order to access the files on your NAS, you should have a DLNA server running on the NAS (most already have one).
Using a DLNA control-app (PlugPlayer, 8Player or similar) on a tablet will give you access to the files and let you play these via the Playmaker.
*You'll need an adapter cable and you must set the output of the PL/Playmaker to fixed-line - the volume is then controlled via the Ouverture.
Newbie:Thank you for answering. I find that the BS5 is such a beauty and I want to have it ;-) Waiting for a good Deal on a BS5 not a Encore. Beovision 4-65 MK3, Beosystem 3, Beolab 7.2, Beolab 6000, Beoplay S8, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beosound 2300, Beogram TX2, Beogram 2404, ibundo, Keyring.......
