I can supply correct lamps. They are soldered in.I can also supply correct belts for tapedeck and turntable (with mounting instructions), and also new idler wheel and reeltable rubber parts.Sorry to say this, but unfortunately it's a fact, that if you bought belts off Ebay or similar, you will most likely get nothing butstandard off-the-shelf types and that won't work.
Email sent..
