Master Control Panel 5500 with Playmaker?
This post has 1 Reply | 0 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Jun 22 2016 5:23 PM
I am trying to use my old MCP5500 with my Playmaker. It doesn't work.
Is there any way to set it to one-way only? The Beo4 works, and I was under the impression that the MCP5500 sends Beolink 1000 commands, so it should have worked.
Or or did I just waste a whopping 7€ on batteries?
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Jun 22 2016 6:01 PM
Some of the simpler commands - such as source, standby, vol-, vol+, perhaps digits - are Beolink 1000 compatible so it should work to some extent. The problem with the MCP is that it always expects to receive a two-way reply before allowing another command. If it doesn't arrive, you will need to wait for the command to timeout with NO CONTACT, and there's no way to turn this behaviour off.
If the Playmaker doesn't respond at all, then perhaps there's some other issue I'm not aware of.
--mika
Page 1 of 1 (2 items) | RSS
