Beocenter 2 not working
gerspee
Posts 12
gerspee Posted: Thu, Jun 2 2016 11:14 AM
Bought this set set and is not working . Only load CD works and open en close function . Power led burns and react on remote and hand touching with going of and on  but nu further  action by the beocenter . So nothing to see in the display .
So how to get some life back on it ? Can't give type or serial numbers because last owner removed them for what ever reason ?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
gerspee:
You'll need the PIN code from the previous owner. Failing that you will need to produce your receipt to a dealer to get the Mastercode. But that needs the serial number......
Graham
gerspee
Posts 12
gerspee replied on Thu, Jun 2 2016 3:40 PM
I do have a pincode that came with it but it's not asking for one either when put on . Only the power led is burning and flashing when i touch some buttons .Sad
Ray Fenwick
Moscow
Posts 15
Mine was working fine, then I came home to find it unresponsive to everything - just blinking the power LED.  Any ideas?
Ray
Я люблю Банг и Олуфсен
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sat, Jun 18 2016 1:37 PM
Strange one. Best plug it out for a while and try it again later.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jun 23 2016 9:13 PM
When the BC2 asks for a pincode, at least your dsiplay should work.
With what number starts the serialnumber on the socket?
Page 1 of 1 (6 items) | RSS
