Beogram 1203 Slooow!!! Any help appreciated?
This post has 0 Replies | 0 Followers
Mark
Designer
Posts 4
Mark Posted: Mon, Jul 4 2016 3:59 AM
Apologies if I've not posted this Topic in correct Forum
I've had a Beogram 1203 turntable for past 10 years, originally whilst I lived in UK where it worked a treat and now back in Melbourne, Australia.
Before I started using it here in Melbourne, it was sitting idle for a couple of years.
Once I started using it again, it was a bit temperamental, in particular it was running extremely slow!
I've since had the drive motor dissembled, cleaned, re lubricated and installed from a reputable B&O repairer here in Melbourne (which was suggested to me via this forum)
This seemed to do the trick for a little while but now it is running slowly again.
Any suggestions on what could be causing this?
It used to run so well, and then again directly after it was serviced but now the pain of slow playing records has returned.
Any help would be greatly appreciated!
Cheers!
Page 1 of 1 (1 items) | RSS
