BV7 and Gefen HDMI switchers
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce Posted: Tue, Aug 9 2016 10:42 AM
Hello,
does anyone know if all gefen hdmi switchers use the same ir compatible codes for B&O's BV7 ?
As I will aquire another BV7 - this time a 32" MK3 - I need another hdmi switcher. It's nearly impossible to get the same gefen hdmi switcher I already have.
There're some around on ebay, but with different specs like Gefen 3x1 Switcher HDMI 1.3 or one named Gefen ToolBox 4 x 1 switcher for HDMI 1.3.
Can I use these too ? I want to connect only 2 HDMI devices to the BV7.
Regards
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Aug 9 2016 10:48 AM
MK III has DVI and YPbPr as HD inputs, so no need for HDMI switch....if only 2 inputs are required.
Ralf
BeoIce
Posts 751
BeoIce replied on Tue, Aug 9 2016 11:14 AM
Hello Ralf,
I want to connect a DVB-S receiver and an ATV2. None of these got a YPbPr connection, so I must have a converter anyway, so why not a hdmi switcher right from the start ?
BeoIce
Posts 751
BeoIce replied on Thu, Aug 11 2016 8:42 AM
As I found out so far, all gefen hdmi switchers which use these remotes will work with the integrated gefen puc of BV7:
BeoIce
Posts 751
BeoIce replied on Thu, Aug 11 2016 8:51 AM
So these both older hdmi switchers should work:
Bought both of them on ebay for little money. Will give you definite feedback.
Page 1 of 1 (5 items) | RSS
