Please help.
I need specifications of Beolab 8000 MK1 -mid/bass speaker drivers.
dimensions...ohm..sesitivity...W..?
Can ayone help.
I need to find replacement for them.
Thx :)
It is possible to find it on web ?
The short answer, I'm afraid, would be no.
B&O rarely disclose the T/S parameters for their speaker drivers.Most drivers are custom produced to B&Os specs and it's practically impossible tofind matching replacement drivers anywhere else.It has been like this for decades and I doubt it will ever change.
If you need a woofer, ask your B&O dealer - or find a similar speaker to donate one.In the case of Beolab 8000 I would expect B&O to still be able to supply the correct part.
The woofers from the earliest mk1 with the small dome aren't available. These are replaced with the ones with the bigger flat dome in the middle.
I solved situation.I used the speakers of similar dimensions and power.It works great.
