Hi all I've just got a beocenter 7002 in white any idea of matching speakers ?
I can think of several great options.
The BeoLab 2500 speakers with white frets.
BeoLab 4 speakers with white frets.
White BeoPlay S3 speakers.
There were white frets for the Beolab 4000 speakers, which would go nicely with silver speakers.
All of these except for the BeoPlay S3 speakers might need a little searching and patience for them to show up on eBay.
I seem to recall there being an adapter cable if the BeoCenter 7002 only uses passive speakers and does not have powerlink.
I think that the line-level adapter cable to which I was referring requires the RCA input on active speakers. So this would eliminate the BeoLab 2500 speakers.
For a nice passive speaker option, you might take a look at the BeoVox 3000. A beautiful, flat, on-wall speaker made by B&O.
Thanks so much really appreciate advice
