Hi
My BV6-26 defaults to format 1 and use it only with an Apple TV for video through a converter - so I have to manually select Format 3 everytime I use it - does anyone know what the geometry settings should be for Format 3 - I can then change Format 1 (which is the only settings I can see) to Format 3 and nbot have to change the format setting manually? - at least that's the theory!
