Beomaster 5500 with Beogram 6500/Beocord CD 6500?
This post has 8 Replies | 0 Followers
commander112
Posts 8
commander112 Posted: Fri, Aug 5 2016 10:53 PM
So, it has been many years since I have been in the B&O world and purchased a Beomaster 5500 for the pre amp outputs along with 6500 components (beocord/beogram CD) but they are not working as an integrated system.  Is there a way to make them all talk together or will I need to find 5500 components?  I swear that 6500 pieces would work with a 5500 but it isn't happening.
leosgonewild
Helsinki, Finland
Posts 2,373
You might hav put the cd in the tape and vice Versace. Try changing them.
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Aug 6 2016 11:57 AM
For both Beocord & Beogram CD, it should "just work". I bet the previous owner(s) has socialized pins 6 & 7 from the DIN plugs.
--mika
commander112
Posts 8
Thank you both for your answers.  I'm not sure what that means.  It plays so I know I have things plugged into the right locations but I have no functionality through the remote.  Also get no information through the remote on the media.
commander112
Posts 8
Double post.  Sorry.
leosgonewild
Helsinki, Finland
Posts 2,373
Does the BM5500 react to the remote at all?
commander112
Posts 8
Yes, the BM5500 is functioning with the remote.  Just not the CD6500 or BC6500.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Check the pins in the DIN plugs. You will need to have at least 6 pins in both!
Regards Graham
commander112
Posts 8
Both the CD and Tape Deck have 7 pin din connectors.
Page 1 of 1 (9 items) | RSS
