I have recently updated my BV11-40 with an AppleTV 4K and also installed the latest PUC-table for it.
During the setup on the BV11 I'm asked if the AppleTV should be turned off when switching to other sources. I have selected this feature, but it dosn't seem to work.
I have noticed that if I'm streaming from an app on the AppleTV and then just change to normal TV, the streaming continues on the AppleTV.
Does anybody experience the same and/or have a solution to make sure that the AppleTV will go into standby when changing source on the BV11?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Dyssegaard: I have noticed that if I'm streaming from an app on the AppleTV and then just change to normal TV, the streaming continues on the AppleTV.
I have the same experience, The ATV keeps running.
I have not bothered, since the powerconsumption is quite low:
Sleep/Network standby 0.36W
Streaming HD movies 2.32W
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Dyssegaard: During the setup on the BV11 I'm asked if the AppleTV should be turned off when switching to other sources. I have selected this feature, but it dosn't seem to work.
Personally I leave my Apple TV running. Why? There's no moving parts, needs to be online to auto-update and goes in to a 'standby' mode by default anyhow to save energy.
...and what happens, when you STOP streaming, before you change to ‘normal tv’?
Millemissen:...and what happens, when you STOP streaming, before you change to ‘normal tv’? MM There is a tv - and there is a BV.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
