Video Master Avant RF 28 inch, Audio master Beosound 9000, Link room BV3 32inch with BL6000's and BS3000. what option progs are required for the BS 3000 to play through BV3 surround sound speakers. Have tried option 5 on both BV3 and BS3000 but cannot get any sound. Also tried VOPT 6 and AOPT0 but can only activate audio master (BS9000). Any suggestions?
Stevemac
Try the BeoSound3000 in option4. This is the special link mode. CD commands got to the BeoSound3000 in the local set up. Link CD commands go to the BeoSound9000 audio master in the main room. The BeoVision3 should be in option6
You will need to add the "Link" command to the List button on your Beo4.
Opman
Thanks, I will try to night and let you know the outcome.
Regards, stevemac
I'm afraid it will not work. BS3000 will need its own pair of speakers as it cannot be connect to video slave BV3.
hfat
hfat: I'm afraid it will not work. BS3000 will need its own pair of speakers as it cannot be connect to video slave BV3. hfat
Yes! Only solution to use the BLb 6000 by the slave BV3 TV (v.OPT 5) as well as by the slave BSd 3000 (A.OPT 5) will be using a Bosscom Powerlink switch for switching between both PowerLink signals.
Spot on! I cannot prog BS3000 in AOPT4, thanks for the help
Best Regards, Stevemac
