I got a notification about a new software update for H8. The update failed and I can't turn on the device anymore. The LED is always off.
The error message: Ycs9l
Anyone else seen similar problem?
shakov:Hi, I got a notification about a new software update for H8. The update failed and I can't turn on the device anymore. The LED is always off. The error message: Ycs9l Anyone else seen similar problem? Thanks
