Beovision 1
This post has 10 Replies | 0 Followers
Aaron Evans
London
Posts 39
Aaron Evans Posted: Tue, Mar 5 2013 11:37 PM
I have just purchased a beovision 1 TV but with no remote control. Is there another remote that I could use? Also is e bay the only place I might be able to find one? Does anyone know any other sites advertise b&o for sale?
westonetwo
Posts 7
Silver Member
I think you'll need either the beo 1 or beo 4 remote controls.
Lifestyle AV advertised above has some beo 1 remotes for £95 http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=1570
If your looking for an alternative brand that works then there are some difficulties, most learning remote controls will not work with with B&O equipment due to the different frequencies used but there are exceptions (from experience with a Sony RM-VZ950T and a Beosound 1 you might find it gives limited functionality though).
Hope this helps.
Chris Townsend
Qatar
Posts 3,531
Hi Aaron, the Beo4 remote is one of the best items that B&O produces and i wouldn't recommend getting a different make even if it is compatible. Try looking on some popular auction websites too.
The Beovision 1 is a great looking TV isn't itYes - thumbs up
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Mar 6 2013 12:03 PM
I bought a Beo 1 on eBay for about £20 so keep looking as they appear a couple of times a month at far less than £95.
The functionality is very limited, hence if I were you I would get a Beo4 - I would think you are likely to expand your collection so it's pretty future proof.  There's 3 Beo4s for sale now from another member here:
http://archivedforum2.beoworld.org/forums/t/5125.aspx
Aaron Evans
London
Posts 39
The first time I used this Forum I said I was starting to get a bit addicted to B&O. Since then I have replaced my speakers with redline 60.2 s still looking for a cd 50 to go with my amp. And now I just got the TV for £30 I can't believe for that money I can buy something so stylish, great and modern looking. Thanks for your help I will keep looking.
Chris Townsend
Qatar
Posts 3,531
Guys correct. Being a bloke it won't be long before your shoe horning some Beolab 5's and a Beovision 7-55 into your flat etc
The Beo4 gives you much more long term flexibility.
Aaron Evans
London
Posts 39
On eBay at the moment there is a remote the seller says that it is a beovision original, but it is not the bright silver one is this correct info? Thanks in advance.
Aaron Evans
London
Posts 39
Thanks Chris , you are right I got a remote for £20 on eBay I also saw a mx 4000 hardly used with remote for £10!!!!! I couldn't resist so I now have that too. Just need to find room for it now. I am new to the b&o "scene" I don't know when it will end the wife is not the most understanding the budget is limited but I am finding some great deals. When will it end????
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Mar 20 2013 9:37 PM
Early BV1's and BC1's work with the Beo 1. Later BV1's really need a Beo4. The Beo1 can, in theory, be re-programmed to operate a later BV1, but this is not always successful. (Search the archive for further info.)
Graham
Cleviebaby
Exeter, United Kingdom
Posts 672
Crashwhu:
It won't!
You seem to be suffering from the initial stages of the 'Beovirus'. Beware - there is no known cure.
Cleve
elgaard
Posts 1
elgaard replied on Wed, Aug 24 2016 12:15 AM
You might be able to use a universal remote. I tried an old Marmitek 8in1 remote.and it worked somewhat using code 199.
At least power on and volume works.
(it know it is an old question, but someone might search this forum(.
Page 1 of 1 (11 items) | RSS
