I bought used Beolab 1 speakers , don't understand where the power going inn.
i am missing a board at the bottom, where can i buy?
https
what do i do ?
I want connect to a PC, just for the sound how do i do that.
Help
Asfa
i am trying to post a pic links not working
Hi Asfa,
You can see the sockets under a pair of Beolab 1 speakers here:-
http://sound-affair.com/media/catalog/product/cache/1/image/1800x/254692c5d529242f802ac5ee4bedf4cd/b/e/xbeolab-1-connections.jpg.pagespeed.ic.w_hDaKCVUg.jpg
You need a mains power cable for each speaker:-
http://soundsheavenly.com/search?controller=search&orderby=position&orderway=desc&search_query=mains&submit_search=
To connect two speaker to a device with a headphone socket (ie. your PC), please use this cable, which connects to the RCA/Line socket under each speaker (not the 8 pin sockets):-
http://soundsheavenly.com/line-in-connection/77--trs-2rca-.html
Please set both speakers to "Line" mode using the small switch next to the input sockets.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
