Sorry and thanks in advance!
I have a BV10-40 and recently moved house- now trying to set up my BV10 by myself instead of with pros (I'm a bit more remote!)... Despite searching the user guides I can't seem to find the "power mains' input on the connection panel. Is it possible that the original setup used only a 'masterlink' or HDMI for power instead of the original 'mains supply' as outlined in the user manual (pg 38 'connections panel')?
type number is 9573
any suggestions greatly appreciated...
Hi Adam,
Your TV does require its own mains power cable, it cannot be powered via Masterlink. The mains socket should be on the far left side of the connection panel under the TV, near to the AV1 and RF Out sockets, but set slightly apart from the other socket panels.
If you don’t already have the mains power cable for the TV, I keep these in stock here in a choice of lengths:-
http://soundsheavenly.com/search?controller=search&orderby=position&orderway=desc&search_query=mains&submit_search=
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Found it and all good now Steve. Thanks so much for your kind response! Have a great day.
