Stupid question but I can't find a definitive answer online.
It looks like BV11 and BV14 stands and brackets are interchangeable. Can anyone confirm if this is the case because if it is I can see me sticking 14s on my existing wall brackets and buying floorstands to put the 11s into a family members house.
If I need to change all the wall brackets I dont know if I can be bothered.
rednik: Stupid question but I can't find a definitive answer online. It looks like BV11 and BV14 stands and brackets are interchangeable. Can anyone confirm if this is the case because if it is I can see me sticking 14s on my existing wall brackets and buying floorstands to put the 11s into a family members house. If I need to change all the wall brackets I dont know if I can be bothered. Thanks
It´s the same for both!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
