Hi
I have tried searching the forum but I haven't found the answer. How do i control the motorised stand of my BV11 with the Beo5?
thanks
Ben
If the motorized stand is activated in your Beo5, you go to the right zone. Then you push TV or DTV (depends how it is named). Then you need to push the semicircle on the right. There should the motorized stand be mentioned. Now you can choose from the positions there -> look the link.
http://archivedarchivedforum2.beoworld.org/forums/t/40098.aspx
