My dealer was not sure. Does Multiroom work on the Moment as seen in the picture?
Brigantinus:My dealer was not sure. Does Multiroom work on the Moment as seen in the picture?
If i buy a e.g. a BS1 or an A6 and tell the Moment it's a connected speaker, the "Join Button" appeares on the screen?
I don't need the iPhone app? Sounds like a magic device..... ;)
Brigantinus: If i buy a e.g. a BS1 or an A6 and tell the Moment it's a connected speaker, the "Join Button" appeares on the screen? I don't need the iPhone app? Sounds like a magic device..... ;)
1: it is not a connected speaker - it's a device on the NL network with it's own sources (and speaker/s), and you can join these (at least some of them) from the BS Moment.
2: no.
3 yes.
