hi i have a 3000-2 beomaster can any one tell me if there is a test for the transformer to check if its ok.the 2 1amp fuses keep blowing
desolder all secondary connection and plug it in. Then there should be about 43 V AC and 22 V AC at the secondaries.
Chris
hi chris thanks for that ill give that a go
